ssl site access even in BYPASS
Apr. 18, 2017, 06:17 PM
RE: ssl site access even in BYPASS
(Apr. 18, 2017 01:08 PM)ProxRocks Wrote:  SSL pages are NOT FILTERED by Proxo even though i have the SSL patch and the SSL dll's (and renaming certs.pem so Proxo can't find it)...
Proxomitron's log window should have shown traffic, if all was correct.
(Apr. 18, 2017 01:08 PM)ProxRocks Wrote:  getting a way to FILTER *SSL* pages without the D@MN warning pieces of SH#T is a *MUST* - any advice?
half-ssl used to work, i've had too many 'issues' with half-ssl so i've been using QupZilla and the IGNORE ALL SSL WARNINGS setting...
ProxHTTPSProxyMII or Proxydomo.
(Apr. 18, 2017 01:21 PM)ProxRocks Wrote:  the *ONLY* one i am having issues with is Capital One...
(Apr. 18, 2017 04:58 PM)ProxRocks Wrote:  been able to resolve how IE8 thru IE11 simply does NOT work on that site...
Capital One's tech support (after VERY HIGH CALL VOLUME) gave me a different link to use...
Google shows others having your problem.
I remember something like this happening on xppro. I don't remember the bank.
It worked right after I set the computer to the correct time.
There could be a dns problem.
Apr. 19, 2017, 04:45 PM
To ease, I hope, a transition to ProxHTTPSProxyMII:
Download "Mod2ProxHTTPSProxyMII.cfg".
Merge with your cfg, first select "Global Settings" and "External Proxy List" in Proxomitron's Merge-O-Matic dialog.
Disable halfSSL in new cfg.
Rename and save this new cfg.
Download my current ProxHTTPSProxyMII folder at https://1fichier.com/?dp5otr4ep4, http://prxbx.com/forums/showthread.php?tid=2172&pid=19062#pid19062
Extract folder, ProxHTTPSProxyMII 1.4 34cx_freeze5.0.1urllib3v1.2Win32OpenSSL_Light-1_0_2k-1_1_0e.
Add folder's "CA.crt" to your browser's store.
Change Browser to send HTTPS requests to 8079.
Start ProxHTTPSProxy.exe
Test [fingers crossed]
.cfg  Mod2ProxHTTPSProxyMII.cfg (Size: 570 bytes / Downloads: 743)
Apr. 19, 2017, 07:36 PM
downloaded...
but not really urgent at the moment, to be honest...
i personally prefer a route where the browser's "certificate store" is non-existent, fully bypassed, never checked, never updated, totally ignored, et cetera...
Apr. 21, 2017, 09:01 PM (This post was last modified: Apr. 21, 2017 09:02 PM by ProxRocks.)
(Apr. 19, 2017 04:45 PM)JJoe Wrote:  Test [fingers crossed]
progress report -
QupZilla [v1.8.9] (portable) -
Capital One 360 Sign In page does the same exact thing that IE8 thru IE11 does (green button turns light green but then NOTHING).
so using ProxHTTPSProxyMII gains me NOTHING.
(edit: but this is a Capital One 360 web site design flaw!)
Pale Moon [v26.5.0] (portable) -
https://verified.capitalone.com - ProxHTTPSProxyMII log and Proxomitron log both show traffic.
Capital One 360 sign in works.
but now Proxo's "menu" (sidki config) in the lower right corner is missing.
no cert warnings, so a step in the right direction.
Opera@USB [v12.18] (portable) -
Proxo's "menu" (sidki config) is back, so step in the right direction
cert warnings every SSL visit - but at least i can "remember my choice" and select Approve.
Capital One 360 working!
so i guess i have a "fix"...
was preferring QupZilla initially, but it hangs sometimes on exit anyway...
plus QupZilla loads 125k+ and two processes into memory (kind of a bloat)...
was my go-to just to avoid d@mn cert warning POS...
the cert CRAP really was my driving factor!
Pale Moon loads 80k+ and also two processes into memory..
Opera@USB loads just over 40k and only one process...
Opera@USB should have been the go-to all along...
okay, with this info, i decided to *remove* ProxHTTPSProxyMII and just go back to Browser+Proxomitron...
also reverted to Opera's default "cert store" (NO cert for Proxo, no approved certs for Capital One 360)...
just the scheme of Proxo SSL Patch and the deleted/renamed certs.pem...
NO CERT WARNINGS...
also no Proxo "menu" (sidki config) at verified.capitalone.com
other than the "menu", everything is working fine, logging in, filtering, no warnings, etc
so my "fix" is to NOT use ProxHTTPSProxyMII and to use Opera@USB for SSL sites...
many thanks for the ProxHTTPSProxyMII suggestion, just not really my cup of tea (i really really REALLY prefer a method where i don't have to "import" certs and nor do i have to 'approve' certs while browsing)...
Apr. 21, 2017, 10:51 PM (This post was last modified: Apr. 22, 2017 12:00 AM by ProxRocks.)
the saga continues...
now i cannot get CHASE to work with Opera@USB or with Pale Moon Sad
Apr. 22, 2017, 04:25 PM
(Apr. 21, 2017 09:01 PM)ProxRocks Wrote:  but now Proxo's "menu" (sidki config) in the lower right corner is missing.
Probably due to 'mixed' content. The browser 'sees' https but the menu's code is served from http. Many (most?) browsers have a setting to allow this. Some older ones didn't care.
(Apr. 21, 2017 09:01 PM)ProxRocks Wrote:  cert warnings every SSL visit
I suspect the ProxHTTPSProxyMII cert was in the wrong place, absent, or somehow incompatible.
Apr. 24, 2017, 06:17 AM (This post was last modified: Apr. 24, 2017 07:35 AM by ProxRocks.)
you are correct - mixed content...
Apr. 24, 2017, 09:29 AM
tried Portable Chromium 15 and 46...
--ignore-certificate-errors --allow-running-insecure-content
some 'secure' sites don't think v46 is "new enough" Sad
best bet so far seems to be (and i really REALLY hate HATE this!) is Portable Firefox ESR v52.1.0 (which does open the door for "newer" Avant than my first trials with Avant)...
in Firefox's "about:config", changed 'security.mixed_content.block_active_content" to FALSE
NOT using ProxHTTPSProxyMII...
NOT using half-SSL (may try to bring this back, undecided)...
NOT using Prox's "certs.pem"...
AM using ssl-patched Proxo...
AM using SSL dll's...
Apr. 25, 2017, 01:11 AM
Firefox is ruled out (thankfully!)...
giving up on one browser for all (several dozen ssl sites are needed for work)...
i'm able to get all BUT ONE to work with QupZilla...
that solitary ONE works 'best' in Chromium...
really ticks me off that the ONE won't play nice !!! !!! !!!
but i can tell from the source code that they are still "tinkering", so who knows a month from now...
Jul. 25, 2017, 05:57 AM (This post was last modified: Sep. 23, 2024 07:11 AM by Chatfield.)
(Apr. 21, 2017 10:51 PM)ProxRocks Wrote:  Firefox is ruled out (thankfully!)...
i'm all about phenq and able to get all BUT ONE to work with QupZilla...
I can't get chase to work with Pale Moon either.
