Firefox and IE8
Jan. 01, 2010, 08:04 PM
Firefox and IE8
When I do a Google search using IE8, it displays with a white background and the AVG safe site feature works
When I do a Google search using FF, it displays with a dark blue background and the AVG safe site feature doesn't work. FF is definitely using Proxo and IE8 is my default browser. Any suggestions? TIA Al |
Jan. 02, 2010, 02:13 PM
RE: Firefox and IE8
That's normal if you didn't set Proxo as the proxy in IE8.
Jan. 04, 2010, 12:51 PM
(This post was last modified: Jan. 04, 2010 01:06 PM by ardarby.)
RE: Firefox and IE8
(Jan. 02, 2010 02:13 PM)whenever Wrote: That's normal if you didn't set Proxo as the proxy in IE8. It seems I hadn't set up the [No Proxy] fields in both browsers correctly. IE8 was OK, but FF was wrong. IE8 included Google and FF, because it was wrong, didn't. Once I got that sorted, removed Google from both and cleaned up the syntax, they now work the same. Thanks. Now I have to figure out why AVG AV flags "safe sites" in IE8, but not in FF. *** Update: Seems it's a "known problem" with AVG. :o( Al |
