Fake cookie function.
Apr. 24, 2008, 10:59 PM
Hi,
I'm new to this forum,
I have some problems with the fake cookie filter by sidki,
This is the some post I made on the castlecops forums, but I couldn't get it working with the help I received there (Thanks to whenever who did everything he could to help me, but I think the problem must be with the filter itself.
So, here goes :
I'm trying to fake a cookie value for some site, so I added this line into the IncludeExlude-U.ptxt file
[^.]+.sitename.com/ $SET(0=f_cookie.) $SET(sCookieF=browserID=Superbrowser)
According to the helpfile, this should replace the browserID value in the cookie with "Superbrowser" and that it does, unfortunatelly while it does that it also destroys any other cookievalues which were originally there.
When I access the site, the cookie is sent like :
Cookie: browserID=Superbrowser
In the response I get there is this :
Set-Cookie: sessionID=b939f638; path=/; domain=.sitename.com
So, I expect the next request I make to the site, this cookie will be sent :
Cookie: browserID=Superbrowser; sessionID=b939f638; path=/; domain=.sitename.com
...unfortunatelly, the filter somehow deletes all the contents, and only sends :
Please, what am I doing wrong, or does the filter deletes everything else by default ?
I'm just interested in anyone else trying out to fake part of some site's cookie, but I expect them to get the same results as I have.
either $SET(sCookieP=0)$SET(0=f_cookie.) doing exactly that, not faking a cookie, so if the site sets the cookie browserID=Firefox, the cookie isn't changed into browserID=Superbrowser (= not good)
or $SET(sCookieP=1)$SET(0=f_cookie.) doing just a blind add, resulting in double values being sent. (browserID=Firefox; browserID=Superbrowser) (= not good)
or the simple $SET(0=f_cookie.) which does nothing else than blindly overwriting the whole cookie string, not taking into account the restrictions set by for example $SET(sCookieF=browserID=Opera) only altering the browserID value, but rather simply overwriting EVERYTHING.
The Fake-Cookie filter from sidki is this one :
Key = "Cookie: 2 Fake Cookies on sel. Sites     7.07.24 [sd] (d.0 l.3) (Out)"
URL = "($TST(keyword=\0&*.(a_cookie|i_level:[12]).)|$LST(AllowCookies))$SET(keyword=$TST(\0=\1.f_cookie.\2)\1.\2)$SET(sCookieP=)$SET(sCookieF=)PrxFail$TST()|$TST(\0=*.f_cookie.*)"
Match = "\0&($TST(sCookieP=0(^$TST(\0=*))|1$SET(1=; \0))$SET(sCookieP=)|(^$TST(sCookieP=*)))"
Replace = "$GET(sCookieF)\1$SET(sCookieF=)"
Please, can anyone help ?
Apr. 24, 2008, 11:32 PM
RE: Fake cookie function.
My solution would involve using $SET(sCookieP=1), but then as you've stated, it may result in double-values being set. The filter does need to be modified for your purposes. An idea I have is getting the name of the attribute in the fake cookie, testing the actual cookie to see if it exists. IF it exists, then replace only its value. ELSE, append the entire attribute name and attribute value to the actual cookie.
I'm a bit strapped for time as I need to finish studying for my last final examination tomorrow, but I'll try to play around with this idea soon.
Apr. 24, 2008, 11:46 PM
Cool RE: Fake cookie function.
Ah great ! Thank you Kye-U.
Looking forward to it & all the best tomorrow ! Cool
Apr. 25, 2008, 02:26 PM
Kye-U Wrote:My solution would involve using $SET(sCookieP=1), but then as you've stated, it may result in double-values being set.
Hello Kye-U! Smile!
The original discussion is at http://www.castlecops.com/t218887-Fake_c...ites.html.
Apr. 25, 2008, 11:54 PM
I seem to have problems testing my filter (even the original Fake cookie filter doesn't seem to be working), but I just wanted to post this anyways to give people an idea of what I'm after:
Key = "Cookie: 2 Fake/Replace Selected Cookies (Out)"
URL = "($TST(keyword=\0&*.(a_cookie|i_level:[12]).)|$LST(AllowCookies))$SET(keyword=$TST(\0=\1.f_cookie.\2)\1.\2)$SET(sCookieN=)$SET(sCookieV=)PrxFail$TST()|$TST(\0=*.f_cookie.*)"
Match = "\0&($TST(\0=\1$GET(sCookieN)=\2(;|)\3)$SET(9=\1$GET(sCookieN)=$GET(sCookieV);\3)|(^$TST(\0=*$GET(sCookieN)=*))$SET(9=$GET(sCookieN)=$GET(sCookieV);\0))"
Replace = "\9$SET(sCookieN=)$SET(sCookieV=)"
What you'd put in IncludeExclude-U:
Quote:[^.]+.domain.com/ $SET(0=f_cookie.) $SET(sCookieN=CookieName) $SET(sCookieV=CookieValue)
Theoretically, it should be working. The way I created this filter was, I started off with a fresh new filter, then entered some expressions, tested it, entered some more, entered some operators and tests, and when it was fully working, I injected the $GET() values in place of my test name and value, and added in the URL Match. Thus, it should work. (Make sure you backup the original filter just in case)
I'm pretty rusty with Header filters. Let me know how it goes!
This filter would replace the previous filter. It simply replaces the value of the attribute if it exists. If the attribute doesn't exist, then it'll insert the attribute and value at the beginning of the cookie. So, no functionality is lost with this filter Smile! (if it works, that is!)
Apr. 26, 2008, 10:27 AM
Hi,
I just tried this filter, it works partially, it does replace value with faked value, but cookie values are glued together like :
Cookie: browserID=OperasessionID=16515165df
instead of :
Cookie: browserID=Opera; sessionID=16515165df
so, in some way, the "; " part of the filter doesn't work.
Greets.
Apr. 26, 2008, 07:55 PM
That's great! Try this:
Match = "\0&($TST(\0=\1$GET(sCookieN)=\2(;|)\3\4)$SET(9=\1$GET(sCookieN)=$GET(sCookieV)\3\4)|(^$TST(\0=*$GET(sCookieN)=*))$SET(9=$GET(sCookieN)=$GET(sCookieV);\0))"
Aug. 06, 2008, 07:41 PM
Great ! Big Teeth
* Sorry for the late reply.
Aug. 06, 2008, 07:46 PM
Let me know if it works Smile! If it does, I can include it as an unofficial update for Sidki's config set!
Aug. 22, 2008, 10:56 AM
(Aug. 06, 2008 07:46 PM)Kye-U Wrote:  Let me know if it works Smile! If it does, I can include it as an unofficial update for Sidki's config set!
Hi Kye-U,
Again, sorry for the late reply.
It works perfectly well !Smile!Hail
Aug. 22, 2008, 01:52 PM
saw this in the "beta updates" and gave it a whirl...
seems to work, but, um, "how" do i use it here -
http://www.msfn.org/board/forums.html
my "old" fake cookie looked like this, edited of course -
    $SET(0=f_cookie.)
    $SET(sCookieF=member_id=123456;pass_hash=hex;coppa=0)
ie, my "fake cookie" has THREE "names" and THREE values...
how do i get that to work with the new 'unofficial' filter update?
Aug. 22, 2008, 02:55 PM
(Apr. 24, 2008 10:59 PM)Toppy Wrote:  or $SET(sCookieP=1)$SET(0=f_cookie.) doing just a blind add, resulting in double values being sent. (browserID=Firefox; browserID=Superbrowser) (= not good)
I think this could be solved by adding an entry in CookieValues.ptxt to remove the incoming browserID part.
Aug. 23, 2008, 03:32 AM
(Aug. 22, 2008 01:52 PM)ProxRocks Wrote:  my "old" fake cookie looked like this, edited of course -
    $SET(0=f_cookie.)
I've updated the filter in the sticky to use a different "keyword", f_cookie2 instead of f_cookie. You can use both filters simultaneously (as long as there are unique URL matches in the IncludeExclude-U blocklist). I forgot to take into account that being able to spoof multiple cookie attributes is a pretty handy thing D'oh!
Aug. 23, 2008, 01:11 PM
Kye-U, seems you accidentally opened up a can of worms, lol...
the "problem" with altering sidki's original "Cookie: 2 Fake" by changing sCookieF is that the "original" IncExc file would ALSO need changed -
blogsearch.google.
books.google.
images.google.
news.google.
http://www.google.com(:[0-9]+|)/a(ccounts|nalytics)/
http://www.google.[^:/]+/(intl/[^/]+/(^?)|search\?(^q\=cache:)|webhp|(^?))
http://www.google., ([^.]+.|)nytimes.com/
http://www.al.com/
http://www.cleveland.com/
http://www.masslive.com/
http://www.mlive.com/
http://www.nj.com/
http://www.nola.com/
http://www.oregonlive.com/
http://www.pennlive.com/
http://www.silive.com/
http://www.syracuse.com/
http://www.cio-today.com/
([^.]+.|)amarillo.com/
([^.]+.|)hollandsentinel.com/
(http://www.|)dailycomet.com/
(http://www.|)gadsdentimes.com/
(http://www.|)goupstate.com/
(http://www.|)houmatoday.com/
(http://www.|)starnewsonline.com/
(http://www.|)the-dispatch.com/
(http://www.|)theledger.com/
(http://www.|)tidesports.com/
(http://www.|)timesdaily.com/
(http://www.|)tuscaloosanews.com/
(http://www.|)wilmingtonstar.com/
([^.]+.|)newsok.com/
([^.]+.|)salon.com/
(http://www.|)caller.com/
(http://www.|)commercialappeal.com/
(http://www.|)courierpress.com/
(http://www.|)dailycamera.com/
(http://www.|)gosanangelo.com/
(http://www.|)independentmail.com/
(http://www.|)kitsapsun.com/
(http://www.|)knoxnews.com/
(http://www.|)redding.com/
(http://www.|)tcpalm.com/
(http://www.|)timesrecordnews.com/
(http://www.|)venturacountystar.com/
(http://www.|)reporternews.com/
http://www.theday.com/
http://www.chicagotribune.com/
http://www.latimes.com/
and therein is why some have also mentioned Google "functions" being now askew...
i'm all for adding the functionality of "fake/replace", but we are probably best off leaving the "original" Cookie: 2 Fake as-was and any site we want this added funtionality will be limited to our Inc-Exc-U files and won't interfere with the original IncExc...
