[Req] Removing Post Signature
Oct. 07, 2005, 09:45 PM
Hi all, I visit a lot of forums and I was wondering whether it's possible to create a filter that removes the signatures from the posts... and if possible the removed signature should not leave an empty space.
Example URL: http://www.gtaforums.com/index.php?showtopic=216833 I use Firefox v1.0.7 with Sidki's latest config. I did a lot of searching before I decided to request a filter here. I came across two possible solutions but unfortunately they didn't work for me. 1. An extension for firefox http://extensionroom.mozdev.org/more-inf...tter_phpbb 2. A filter for Proxomitron Name = "Signature Clear" Active = TRUE URL = "forum.ru-board.com/" Limit = 256 Match = "<br><span class=sing>----------<br>*</span>" I found the above filter at http://www.forum.ru-board.com/topic.cgi?...9&start=40 The link is apparently down at the moment. Any help will be appreciated and please let me know if I have not properly explained what I want the filter to do. Thank you |
Oct. 07, 2005, 10:08 PM
maxbaggi, there are two apparent problems with that filter:
1. The URL Match is too specific. In the filter I wrote, I made it apply to all HTML pages. 2. The matching expression is written to only match the one over at ru-board.com. Here is a filter I quickly wrote and should work with most forums. If you find any forum where this filter doesn't work, post the link here and I'll update the filter. It should work for most phpBB forums.: Code: [Patterns] |
Oct. 07, 2005, 10:30 PM
Thanks Kye-U, the filter works on most of the forums I visit
But there is one that is still displaying signatures. I will pm you the link in a few minutes... thanks again
Oct. 07, 2005, 11:00 PM
Code: [Patterns]
Oct. 07, 2005, 11:26 PM
Thank you so very much, Kye-U
It works like a charm
Oct. 08, 2005, 01:50 PM
(This post was last modified: Oct. 08, 2005 05:34 PM by ProxRocks.)
Needs a little more help...
See signature for Shea (sorry Shea, it just happened to be an example) on the UOP... for example, see Shea's signature in the reply below... ps: besides, I luv ya Shea, I'm a New York METS fan (ie, Shea Stadium)... |
Oct. 08, 2005, 04:56 PM
I see, it's because on invision boards, they use <span> tags for different colors of text. So it doesn't go all the way to the end of the signature, just the next </span>
�{=(~�::[Shea]::��~)=}� How 'bout you sideburns, you want some of this milk? This fading text is pretty cool, eh? I bet you wish you had some. |
Oct. 08, 2005, 06:11 PM
Code: [Patterns]This one should work better
Feb. 12, 2006, 07:37 AM
Updated to match SimpleMachines and punBB:
Code: [Patterns] |
Aug. 01, 2007, 11:52 PM
RE: [Req] Removing Post Signature
Its not working for me.
Aug. 02, 2007, 12:44 AM
What is the link to the forums that it doesn't work on, or, what is the forum software that is it not working with?
![]() Welcome, by the way
Aug. 02, 2007, 12:57 AM
Well, its not working in this thread. Also, I tried it at the forums on http://www.gp32x.com and it didn't work their either. Maybe the script is not being copied/pasted correctly.
Thanks for the welcome. |
Aug. 02, 2007, 01:31 AM
Code: [Patterns]Updated to match MyBB and made first match more generic (by replacing single quotes with $AV())
Aug. 02, 2007, 02:41 AM
Thanks for updating it. It works now.
Aug. 02, 2007, 07:17 PM
Actually, it doesn't work all the time. Signatures that have quotes in them aren't being filtered.
