Windows Server 2003 + General slowness on XP
Nov. 03, 2005, 08:59 AM
Hi,
bfilter-0.10.1 don't work on Win2003, nothing happens when starting bfilter.exe. Tried on 2 different systems, even starting it in XP or w2000 compatibility won't work. I noticed major slowness since the new builds on winXP, surfing is very slow, even with the old 0.9.4... i've used bfilter for a year now. I quit using it yesterday on all my systems, and i can't find any alternatives :-( |
Nov. 03, 2005, 04:07 PM
Re: Windows Server 2003 + General slowness on XP
Quote:Hi,Confirmed. I'll see what I can do. Quote:I noticed major slowness since the new builds on winXP, surfing is very slow, even with the old 0.9.4...Do you mean 0.9.4 suddenly became slow? Does it consume much CPU time? |
Nov. 03, 2005, 08:13 PM
Quote:Do you mean 0.9.4 suddenly became slow?I noticed recently that page loads were slower than usual, so i checked out your site and saw you updated bfilter. Is there any relation between the old and the new build, like a (slow) url for image replacement or anything ? After more testing i can say for sure that page loads are faster with the old build. So i'll stick with it. Quote:Does it consume much CPU time?can't tell, no cpu issue so far |
Nov. 03, 2005, 10:51 PM
The problem with Windows 2003 is solved. It didn't like the stable version of the UPX packer. The latest beta works fine. More info here:
http://prxbx.com/forums/viewtopic.php?p=5995 Quote:I noticed recently that page loads were slower than usual, so i checked out your site and saw you updated bfilter. Is there any relation between the old and the new build, like a (slow) url for image replacement or anything ?No, the replacement images are generated by BFilter itself, not taken from an external URL. Version 0.10 had a bug of not detecting connection failures (they timed out instead), that could cause slow page loads. It's fixed in 0.10.1. If it's still slow, I'll build a debug version for you. |
