Proxomitron Reborn
Apr. 09, 2024, 08:06 PM
Post: #241
RE: Proxomitron Reborn
Is all of this supposed to clear this browser warning?
Apr. 10, 2024, 01:55 AM
Post: #242
That may depend upon the browser and the reason for the warning.
I would expect the files that these are replacing to prevent that warning. My guess is you missed a step or more in setting up Reborn for https. Which browser and can you share the details of its warning? (Apr. 09, 2024 08:06 PM)ProxRocks Wrote: Is all of this supposed to clear this browser warning? |
Apr. 10, 2024, 09:09 AM
Post: #243
I get that warning in *EVERY* Chrome-based browser I've ever used with Proxomitron.
I currently use Ungoogled Chromium v114 (I have no use for "newer" versions). What are all of the "steps" and I'll double-check them one-by-one? |
Apr. 10, 2024, 04:27 PM
(This post was last modified: Apr. 13, 2024 03:16 PM by JJoe.)
Post: #244
I think your cert has been deprecated.
I'll look at 'Ungoogled Chromium v114' when I get a chance. Start with the attached files. (Apr. 10, 2024 09:09 AM)ProxRocks Wrote: I get that warning in *EVERY* Chrome-based browser I've ever used with Proxomitron. certificates.zip (Size: 130.37 KB / Downloads: 150)
ReadMe.txt Wrote:Add files to the Proxomitron exe's directory. Edit: Corrections/Details and New files |
Apr. 10, 2024, 07:19 PM
Post: #245
Thanks! The "ProxomitronSSLFilteringRootCA.crt" import fixed it!
Next question - How was this file created in case I ever need to "roll my own" (as sidki used to call it)? |
Apr. 10, 2024, 07:24 PM
Post: #246
(Apr. 09, 2024 12:35 PM)JJoe Wrote:(Apr. 02, 2024 05:09 AM)amy Wrote: Happy Easter! Proxomitron Reborn 4.7.0.0 has been released! I'm assuming that the libcrypto-3.dll and libssl-3.dll files just sit in the main folder alongside the Proxo/Proxomitron .exe? How does one "test" if the .dll's are being used or not? |
Apr. 10, 2024, 07:48 PM
(This post was last modified: Apr. 10, 2024 07:49 PM by ProxRocks.)
Post: #247
(Apr. 10, 2024 07:19 PM)ProxRocks Wrote: How was this file created in case I ever need to "roll my own" (as sidki used to call it)? Disregard, I forgot about the Reborn built-in cert generator. I've tried it in the past and it did not work. I will need to experiment with the settings/options as I've always just used the "default". The "default" generated a cert that did not work. I'll experiment. |
Apr. 10, 2024, 08:34 PM
(This post was last modified: Apr. 13, 2024 02:26 PM by JJoe.)
Post: #248
Use Reborn's certificate generator (Main dialog>>Config>>HTTPS) to generate "proxcert.pem" and "proxcert_certonly.pem".
Use Firefox, OpenSSL, or other to convert "proxcert_certonly.pem" to "ProxomitronSSLFilteringRootCA.crt." (Apr. 10, 2024 07:19 PM)ProxRocks Wrote: Next question - How was this file created in case I ever need to "roll my own" (as sidki used to call it)? Edit: Corrections/Details |
The following 1 user says Thank You to JJoe for this post:ProxRocks |
Apr. 10, 2024, 09:08 PM
(This post was last modified: Apr. 10, 2024 09:09 PM by ProxRocks.)
Post: #249
Here is an easy test.
All you have to do is load this .png and it will tell you if you are TLS 1.2 or TLS 1.3. https://check-tls.akamai.io/v1/tlsv.png |
Apr. 10, 2024, 09:19 PM
Post: #250
I'm still missing something.
I cannot get TLS 1.3 when running through Proxo Reborn. |
Apr. 11, 2024, 12:45 AM
(This post was last modified: Apr. 11, 2024 12:47 AM by JJoe.)
Post: #251
Yes, the libcrypto-3.dll and libssl-3.dll files just sit in the main folder with the new exe.
If you have not, remove or rename the old DLLs, libeay32 and ssleay32. Start Reborn with a cfg that uses SSLeay/OpenSSL, (Main dialog>>Config>>HTTP). A little awkward to mention but I may have made this kind of mistake more than I will admit... Make sure that the new exe is the one being tested. ![]() To test functionality, you can use an online service like https://clienttest.ssllabs.com:8443/ssltest/viewMyClient.html. The Proxomitron's Log Window may indicate TLS 1.3. Log Window Wrote:+++SSL:GET 2142+++ (Apr. 10, 2024 07:24 PM)ProxRocks Wrote: ... (Apr. 10, 2024 09:19 PM)ProxRocks Wrote: I'm still missing something. |
Apr. 11, 2024, 01:38 AM
Post: #252
Also, you can visit http://local.ptron/.pinfo/ssl/ to see some more info on your SSL configuration, including the currently loaded OpenSSL version.
Apr. 11, 2024, 07:26 AM
Post: #253
Okay, I got TLS 1.3 working.
I had two issues. First, I was using all four .dll's instead of just the two new .dll's. Second, I was applying PtronGUI_4.6.0.5(h).exe to Reborn_4700R. Looks like I will have to modify the GUI manually instead. |
Apr. 12, 2024, 09:13 AM
Post: #254
Running the newest Reborn has become a slight nightmare on my system.
I am getting the below error SEVERAL times throughout a browsing session. Is anybody else? I'm on Win10 x64 LTSB and Ungoogled Chromium v114. |
Apr. 12, 2024, 09:47 PM
(This post was last modified: May. 26, 2024 03:06 PM by Anno Domini.)
Post: #255
WOW, an Easter present ! Version 4.7.0.0 ! Thank you s-o-o-o-o much Amy !!! You're a true treasure to the Proxomitron community !!!
Guys, I've said this before. I operate at a 4th grade level when it comes to much of what you talk about here. I read your comments to try and install Version 4.7.0.0 correctly, and I made a short list of what I did in order. Proxomitron's Log Window now indicates TLS 1.3 and it appears to be running fine. Can anyone confirm I updated it properly ? Thank you. 1.) I downloaded ProxomitronReborn_4700R.zip containing the help folder, changes.txt, and proxo.exe. I added those three files to my Proxomitron folder replacing the old ones. 2.) I deleted the old DLLs -- libeay32 and ssleay32 in my Proxomitron folder-- and then added libcrypto-3.dll and libssl-3.dll files in there 3.) I started Proxomitron and generated a new proxcert.pem and exited Proxomitron. 4.) I started my browser, deleted my old Proxomitron certificate, and then added proxcert_certonly.pem to browser's certificate store. 5.) Started Proxomitron, went online, and it works. Proxomitron's Log Window now indicates TLS 1.3. |
