Add "Anti Adblock Killer list by reek" to privoxy. but how?!
Oct. 08, 2015, 12:57 PM
RE: Add "Anti Adblock Killer list by reek" to privoxy. but how?!
Sorry but I never use Rasberry pi before, I think I won't be able to help you this time
![]() But problem is about: - Your browser - Your code - Or maybe GM_function.js But without remoting your computer it is hard for me to help you. |
Oct. 08, 2015, 12:59 PM
can you maybe upload your filter files and config? so i can compare them with my files? which version of privoxy are you using?
Oct. 23, 2015, 06:57 PM
(Oct. 08, 2015 12:59 PM)kik0s Wrote: can you maybe upload your filter files and config? so i can compare them with my files? which version of privoxy are you using? My filter file is very complex, I think it won't work well on your system and config file (config or config.txt) won't cause any problem. I'm using the lastest version of Privoxy, but Privoxy version won't affect how Anti Adblock Killer works. |
Nov. 08, 2015, 08:40 PM
hey there. so i am still working on that issue. for me it seems the problem is in the filter file. for the .js script from reek it is actually needed to add his filter file from here https://raw.github.com/reek/anti-adblock...ilters.txt to any adblocker. i don't know how to add it to privoxy?! any suggestion?
Dec. 06, 2015, 11:03 AM
(Sep. 27, 2015 09:26 AM)cattleyavns Wrote: I have the same result as you, maybe this script is a little bit more complex than other script, but i will try to make it work on Privoxy, because it is a very useful script. How does your filter.file look like as i do not run privoxy on windows I guess the action.file do look the same? |
Dec. 06, 2015, 08:42 PM
@rogern i do not use windows either. maybe thats the case?! but reek changed his .js file already so the filter above does not work anymore. any other hints to make it work some how?!
Dec. 07, 2015, 10:14 AM
@kik0s i run like you on the green subnet privoxy+proximitron proxy+adblocker by dietpi (raspberrypi) along with urlfilter on my gateway/firewall.
On purple network i run privoxy on firewall+ proximitron+dietpi on a raspberrypi. I will see if there is a way to make the script for converting the dietpi to use reek. |
