[F] Update to Google Filters (support for Google SSL)
Dec. 12, 2011, 06:32 PM
RE: [F] Update to Google Filters (support for Google SSL)
JJoe Wrote:Can you post the code that is not matched and the address of the page? Address: http://www.google.com/search?num=100&hl=...09l6-1l1l0 I don't know which part you're asking me, so here you have the clean proxo-modified source and the corresponding debug page. Is that ok? google search.rar (Size: 99.65 KB / Downloads: 879)
JJoe Wrote:eclipse Wrote: This is the bit of code to change: Code: /* Search terms */I'm attaching a screenshot of the rendered page with description of the problems. google search render.jpg (Size: 316.78 KB / Downloads: 908)
JJoe Wrote:Date was a typo. [blush]No harm done!!. I'm more than grateful you take the time to look into this! JJoe Wrote:eclipse Wrote: I'll experiment a bit with different UA strings and report back! (faking IE might be a good preliminary candidate - no ajax / no autocomplete). |
Dec. 13, 2011, 12:48 AM
(This post was last modified: Dec. 13, 2011 12:49 AM by JJoe.)
(Dec. 12, 2011 06:32 PM)eclipse Wrote:JJoe Wrote:Can you post the code that is not matched and the address of the page? (Dec. 12, 2011 06:32 PM)eclipse Wrote: I'm attaching a screenshot of the rendered page with description of the problems. How much is fixed by using http://www.google.com/search?num=100&hl=en&safe=off&site=&q=proxomitron&oq=proxo&aq=1&aqi=g4g-s2g4&aql=&gs_sm=c&gs_upl=4924l5818l0l13481l5l5l0l0l0l0l909l909l6-1l1l0&complete=0 (Dec. 12, 2011 06:32 PM)eclipse Wrote: I don't know which part you're asking me, so here you have the clean proxo-modified source and the corresponding debug page. Is that ok? I'll see what I can see later. (Dec. 12, 2011 06:32 PM)eclipse Wrote:eclipse Wrote:4. In the results page, there's some word highlighting to black (which is impossible to read). This can be easily fixed by changing the correct attribute to !important in google-css-dark.css.This is the bit of code to change: So orange is ok. ![]() File added to other post. |
Dec. 13, 2011, 03:25 AM
JJoe Wrote:How much is fixed by using http://www.google.com/search?num=100&hl=...complete=0 Regrettably not much... (but now the typed text is readable). complete-off.jpg (Size: 107.63 KB / Downloads: 954)
Dec. 13, 2011, 05:26 AM
| RE: [F] Update to Google Filters (support for Google SSL) | |||
Dec. 13, 2011, 05:10 PM
JJoe Wrote:Does the navigation toggle work now? Not at all.... |
Dec. 14, 2011, 03:41 AM
(Dec. 13, 2011 05:10 PM)eclipse Wrote: Not at all.... I don't think I did anything that would fix it but updated |
Dec. 14, 2011, 06:06 PM
Each and everytime that I copy/paste the filters to my config, there's been an extra "?" in this line
"var c=document.getElementById('leftnav').style;c.visibility=c.visibility=='visible'??'hidden':'visible'" from Google Toggle: Left NavBar 11.12.13 (!nn multi) [ozo] (d.s) I did find it by chance, by looking at the code in the javascript error console. Looking at proxo source I thought it was some king of escaping code. Then I looked in the posted filter..... NO DOUBLE "?"!! EUREKA!! Metapad (the editor I'm using) didn't give me a warning when saving. Notepad DID (unicode characters). The problem filters that I identified are: Google Search: Remove Ad Blocks 11.11.21 [sd ku] (d.s) Google Search: Fix Shortcuts 11.07.11 [sd] (d.s) Google Toggle: Left NavBar 11.12.13 (!nn multi) [ozo] (d.s) I tried 2 different browsers, 2 different text editors bypassing proxomitron (just in case) and I ALWAYS get a double "?". JJoe, could you post said filters as an attachment, so I can be sure I'm getting them RIGHT? (or anything else I could try - I'm out of ideas). Didn't happen anything like this before.... BTW, Toggle IS WORKING!
Dec. 14, 2011, 07:07 PM
(Dec. 14, 2011 06:06 PM)eclipse Wrote: I tried 2 different browsers, 2 different text editors bypassing proxomitron (just in case) and I ALWAYS get a double "?". Agreed, posted, tested, seems ok, will investigate later. |
Dec. 15, 2011, 04:51 AM
Dec. 16, 2011, 10:58 AM
It's a new feature in the forum software (after the recent update); I've found the associated option and disabled it. I went back to the original post in this topic and imported the said filters to Proxomitron and they seem to be fine, but please confirm
![]() Thanks JJoe and eclipse for the report! |
