Google Alternate Display - intermittent
Oct. 28, 2011, 02:11 PM
similar to the now-fixed (many thanks to JJoe) Yahoo Auto Login intermittent issue, i'm now noticing intermittent issues with the Google Alternate Display...
do a search, refresh several times...
sometimes the right column sponsored ads will show, most of the time they will not...
same intermittent on-and-off for the left column navigation...
any ideas?
Oct. 30, 2011, 03:21 AM
RE: Google Alternate Display - intermittent
I did not see a navigation column.
For ads and excessive <br> tags try:
Name = "Google Search: Remove Ad Blocks     11.11.29 [sd ku] (d.s)"
URL = "$TST(hCT=*html)(www|encrypted).google."
Limit = 32766
Match = "<("
        "!-- PROX:( Header Bottom Insertion*-->)\1"
        "$SET(0=<!-- PROX:\1\r\n<style type="text/css">#tads,#mbEnd{display:none!important;}</style>\r\n)"
        "|table[^>]++id=$AV(mbEnd)$SET(#=mbEnd.)$INEST(<table,</table)</table >"
        "|div("
        " style=(*>)+{1} <font$INEST(<div,*href=$AV(/history\?*)$SET(#=history-d.)*,</div >)</div >"
        "|([^>]++id=$AV(tpa[0-9]+$SET(#=tpa.)|tads$SET(#=tads.)|side_section$SET(#=side.)|ietb$SET(#=ietb.))"
        "|> <h2(*>)+{1}Sponsored$SET(#=sponsfloat.)"
        "|(*>)+{1} <table[^>]++align=$AV(right)(*>)+{1}( <(*>)+{1}( \&NBSP;)+)+ sponsored$SET(#=sponsoreddivtbl-ad.))$INEST(<div,</div >)</div >"
        "|table ("
        "cellpadding=0 cellspacing=0 border=0> <tr> <td valign(*>)+{1}( <font*>)+{2}([a-z]+ :)\#"
        "(width=$AV(100%) style=$AV(border: 1px solid*)$SET(#=custom-ad.)|align=$AV(right)(*>)+{1}( <(*>)+{1}( \&NBSP;)+)+ sponsored$SET(#=sponsoredtbl-ad.))"
        "|class=$AV(ra)$SET(#=custom-ra-ad.)"
        ")$INEST(<table,</table >)</table >"
        "|(*>)+{1} <tr> <td (^class)(*>)+{1} (<(/td > <td*<)+{0,1}(/+font*<)+|((*<)+{1}/+br+ > )+<)"
        "a href=$AV("
        "/history\?$SET(#=history.)*"
        "|*//(tool(bar|s).|checkout.|desktop.|pack.|survey.|webaccelerator.)\#google(ratings)+.*"
        ")$INEST(<table,</table >)</table >( <br*>)+{0,1}"
        "|center> <font$INEST(<center,"
        "*//(tool(bar|s).|checkout.|desktop.|pack.|webaccelerator.)\#google(ratings)+.*"
        ",</center >)</center >( <(br|p)>)+"
        "|td rowspan=[#2] > <a\s[^>/]+//(tool(bar|s)|checkout|desktop|pack|webaccelerator)\#.google(ratings)+."
        "$INEST(<td,</td >)</td > </tr > <tr> $NEST(<td,</td >)$SET(#= td.)"
        "|p>( <font*>)+(*<)+{1}a\s[^>/]+//(books.)\#google.(*<)+{1}/a >( </font >)+ <br>"
        "(^(^<br clear=all>|<table))"
Replace = "\r\n<!-- PROX-S: Modified/Removed by Google Ad Links Filter (\@) -->\r\n\0"
          "$SET(sSpec=$GET(sSpec)\@)"
Name = "Google Search: Alternate Display     11.11.29 (multi) [sd ku] (d.s) test"
URL = "$TST(hCT=*html)(www|encrypted).google.(*/)+{1}(intl/(*/)+{1}(^?)|search\?(^tbm=isch|*\&tbm=isch)|webhp|(^?))$SET(keyword=$TST(keyword=\1.(i_layout:[#*:0].)+\2)\1.i_layout:2.\2)"
        "(<td class=$AV(j)$SET(classj=1))+"
        "<br>(\r\n+|\n\r+| <$SET(classj=)(^)|$TST(classj=1))$SET(1= )"
        "/b> of (about )+<b>[0-9,]+</b> ((from|over the) $NEST(<b>,</b >) )+for <b>( <b>)+[^<]+"
        "&&((<*>|?)+{95})\2???$SET(1=<\2...)*"
        "</style >(^$TST(b=s))$SET(b=s)$SET(1="
        "</style>\r\n<script type="text/javascript">"
        "var prxSpics=["http://local.ptron/sidki_h_$GET(cfg)/Google/google-","
        "new Image(),new Image(),new Image()];"
        "prxSpics[1].src=prxSpics[0]+"bug.png";prxSpics[2].src=prxSpics[0]+"top.png";"
        "prxSpics[3].src=prxSpics[0]+"new.png";"
        "</script>"
        "\r\n<style id="themed">\r\n"
        "/* Proxomitron "Google Alternate" CSS import */\r\n"
        "@import url(http://local.ptron/sidki_h_$GET(cfg)/Google/google-css-alt.css);\r\n\r\n"
        "/*prox-dummy*/</style>\r\n"
        "<div ("
        "id=("
        "$AV(ie6tb)>$INEST(<div,</div)</div >( $NEST(<script,</script >))+"
        "|$AV(exp_msgs)$INEST(<div,</div)</div >"
        "|style=$AV(margin : -5px 0 5px)$INEST(<div,</div)</div >"
        "$AVQ(("+g)\#((\s*|")\#|))("
        "((^ style=$AV(margin-(left|right)*))($TST(a=odd)$SET(a=even)|$SET(a=odd))|)$SET(3=$GET(a))"
        "(*( href=$AV(/interstitial\?url\=h\9|((*/)+{1}/(*/)+{1})\9?*|*))\5*</a >)\4"
        "<a href="h\9"><img src="http://local.ptron/sidki_h_$GET(cfg)/Google/google-bug.png""
        " width=16 height=10 border=0 title="Malware warning!"></a>&#160;&#160;"
        "<a href="\9"><img src="http://local.ptron/sidki_h_$GET(cfg)/Google/google-top.png""
        " width=10 height=10 border=0 title="Go to top domain"></a>&#160;&#160;"
        "<\2 class=\#&#x20;\3\#\#\4&#160;&#160;\0"
        "<a\5 target="_blank"><img src="http://local.ptron/sidki_h_$GET(cfg)/Google/google-new.png""
        " width=14 height=10 border=0 title="Open in new window"></a>&#160;&#160;"
        "<div class="sfbg nojsv" style="top:30px"></div>"
        "<div class="sfbgg"></div>"
        "<div style="position:relative;height:29px;z-index:2">"
        "$SET(1=<div style="position:relative;z-index:2">)"
        "<a (^(^href=$AV(https+://*encrypted.google.com*) >"
        " <img src(*>&&*alt=$AV(\2)*)))"
        "$SET(1=<a id="logo" )"
        "<div id="logocont""
        "$SET(1=<div)"
        "<div style=$AV(max-width:509px)>"
        "$SET(1=<div>)"
        "max-width$TST(tStyle=*)*(;|?(^(^\})))"
        "#center_col,"
Oct. 30, 2011, 11:23 PM
hmm...
still intermittently missing...
but have found out more to help narrow it down...
the "dark blue" seems ok, it's the "LIGHT blue" that gets the intermittent miss...
and, and i don't know if this is related or not, but when the "light blue" WORKS, there is a "Match: Top Mark: HTML - Fix Tags" match that creates/writes "øøþ<!doctype html>"...
so viewing the source code from within the browser (not Proxo), the very first line is "<!doctype html><html>"...
when the "light blue" FAILS, there is *NO* "Match: Top Mark: HTML - Fix Tags" match and therefore no "<!doctype html>" as the first line of browser-viewed source code...
any ideas? is the <!doctype html> the reason that the "light blue" CSS is not being imported (the "light blue" imports the CSS *differently* than the "dark blue)?
Oct. 31, 2011, 02:29 AM
How is it "missing", styling not being applied, ads showing?
My Google Dark was doing both. I did not check the other styles. I assumed...
Dark and Light both target "<style id="themed">" in the Google code. Dark does more filtering, however.
When it misses, what is the first line of browser-viewed source code?
Are you seeing the ajaxed Google search page? Does the page's address contain a "#"?
Hope they bury this new code but I'll test the other styles when I see it again.
Oct. 31, 2011, 10:44 AM
by "missing", i mean that the styling is not being applied (the ads are blocked)...
when it "misses", the very first line of browser-viewed source code is "<html>" (whereas when it "hits" and the styling is applied, the very first line is "<!doctype html><html>")...
am i seeing "ajaxed"? no clue, what is "ajaxed"?
page's address does not contain a "#"...
Nov. 01, 2011, 01:46 AM
(Oct. 31, 2011 10:44 AM)ProxRocks Wrote:  by "missing", i mean that the styling is not being applied (the ads are blocked)...
When it misses, do you see "/* Proxomitron light blue Google theme */" in the browser-viewed source code?
(Oct. 31, 2011 10:44 AM)ProxRocks Wrote:  am i seeing "ajaxed"? no clue, what is "ajaxed"?
Basically, the ajax page's address would look like "http://www.google.com/#num=100&hl=en&safe=off&q=proxomitron". Some scripts then take the info after the "#" and create the page. Google Suggest uses ajax, I think.
http://en.wikipedia.org/wiki/Ajax_(programming)
I rarely use Light-Blue. Is it supposed to look something like the attached gif?
.gif  lightblue.gif (Size: 53.36 KB / Downloads: 866)
Nov. 01, 2011, 02:46 AM
yep, that gif is what it's supposed to look like when it is working properly...
the intermittent fail will have an all-white background and no search results highlights in the two shades of blue...
i've been getting the "fail" several times a day...
Nov. 06, 2011, 03:30 PM
(Nov. 01, 2011 02:46 AM)ProxRocks Wrote:  i've been getting the "fail" several times a day...
Did you find a solution?
Nov. 06, 2011, 05:09 PM
google stopped "mucking up" on their end...
it's become clear that i was getting intermittent issues because they were changing stuff on their end...
i haven't had the "intermittent" miss for several days - it morphed into no longer being "intermittent" to being permanent...
once it became "permanent", i was able to debug it more effectively Big Teeth
Nov. 16, 2011, 03:37 PM
yeah. too often I edit something for a months old google change, then a week later, google changes again. >8-E
