Page contents to <title> tag
Oct. 28, 2010, 03:34 PM
is there any way to get some page contents into page title tag?
running Oct 23 config. reason need it: on some forums the <title> tag contains meaningless stuff like MS apps and etc, so i want to put in contents of the <div class='maintitle'> i've done something like this Code: [Patterns]![]() thanks in advance for help. |
Oct. 28, 2010, 03:56 PM
RE: Page contents to <title> tag
could i have the link to the site-in-question?
Oct. 28, 2010, 04:47 PM
thanks for the reply. sorry those are private boards, but the engine is a regular Invision Power Board.
i guess during engine setup, paranoia ruled . strangely ruled though i must say.the skin and structure is similar to this one - http://www.homefitness101.com/forum/inde...howtopic=2 for this example lets say i want to update the <title> with some contents of <div id='navstrip' align='left'> i am having troubles not with finding and setting contents of THtit but with updating <title> and adding contents of THtit. because content that i need comes after! <title> has been processed. i hope i'am not confusing and was able to explain what i need. |
Oct. 28, 2010, 07:35 PM
ah, i see the dilemma (contents coming after title)...
perhaps a <body> tag 'onload' of some kind? |
Oct. 29, 2010, 01:21 AM
I think I'd try using the Proxomitron to empty the Title block, capture the text, and add a javascript that uses document.title to modify the title.
Otherwise, BFMI. Remove the Title block, match from </head> to desired text, place new Title block, and replace matched code. HTH |
Oct. 29, 2010, 04:17 AM
I'd try to generate a javascript that alters document.title after identifying the portion of the target DIV to use for it. I'd generate that script either just before the /DIV or after it, and totally ignore what-ever any previous <title> might have been (if any).
Below illustrates the method. In this example the script is appending (via '+=' construct) the string to the previous title content. Maybe you want to assign your desired text instead of append. Code: <html> |
Oct. 29, 2010, 06:06 AM
(This post was last modified: Oct. 29, 2010 06:08 AM by sh8an.)
yay!
![]() Code: \1<b>\2</b>\3\r\n thanks a lot for the hints.
Oct. 30, 2010, 01:40 PM
so many sites have bad titles, this document.title method could be a general filter, that can be customized from an include-exclude or other list file.
_________ my purpose is only to bookmark and only a few sites worth the trouble, so i have a few site-specific filters. the filter creates link to the same page at location on the page where the usable info appears. simplified fake example, before: <h1>text that should be good title, bookmark</h1> after: <h4><a href="\u">text that should be good title, bookmark_website.com</a></h4> |
