Prox filter editor issues
May. 24, 2009, 07:15 AM
(This post was last modified: May. 27, 2009 09:05 AM by sidki3003.)
edit by sidki: split from http://prxbx.com/forums/showthread.php?t...1#pid12441
<a> Remove: Ad Links 7.11.29 [sd] (d.2) I always got a "Syntax Error" message box when I press the Test button in the test window. Does this mean the filter is never effective? |
May. 24, 2009, 07:54 AM
RE: sidki-config: Feb 13 2009
Probably. That can happen if you've edited the config file directly. Get a fresh copy from sidki_oob.ptron.
May. 24, 2009, 12:00 PM
The same thing happened on sidki_oob.ptron.
Is this the proper way to add in AdHosts.ptxt if want to remove a bad link like: <a href="http://www.badurl.com/">link text</a> Code: www.badurl.com $TST(\3=.)Code: www.badurl.com $TST(\9=[/.]) |
May. 24, 2009, 12:47 PM
(This post was last modified: May. 24, 2009 12:54 PM by sidki3003.)
(May. 24, 2009 12:00 PM)whenever Wrote: The same thing happened on sidki_oob.ptron. In that case i don't know what's broken for you. Usually you can trust me that i'm not distributing defunct filters. ![]() Quote:Is this the proper way to add in AdHosts.ptxt if want to remove a bad link like: <a href="http://www.badurl.com/">link text</a> Neither one, because that link doesn't contain any img/input/image/embed tags. The filter name might be a bit confusing. It's just about linked objects, a.k.a. banners. In contrast to the "Remove: Ad Images" filter, which targets images that aren't linked. |
May. 24, 2009, 02:13 PM
(May. 24, 2009 12:47 PM)sidki3003 Wrote: In that case i don't know what's broken for you. Usually you can trust me that i'm not distributing defunct filters.I downloaded the http://sidki.proxfilter.net/prox-archive...-02-13.zip again and the sidki_oob.ptron from the zip file is the same with my local copy. Could any one else check if you have the same problem? Quote:Neither one, because that link doesn't contain any img/input/image/embed tags.So, is there a option in your config to remove pure text ad links? |
May. 24, 2009, 02:30 PM
No, there isn't.
Regarding your "Syntax Error" i have *really* no clue (besides wild ones like your patched exe or Chinese input system), sorry.
May. 24, 2009, 09:33 PM
(This post was last modified: May. 24, 2009 09:39 PM by sidki3003.)
I just had an idea. Maybe your system font is converting characters with accents to something else?
Snippet from the filter code: publici(dad|te|té)|werbung|sponsored (by|links+)|a(dvertising|nzeigen+)(^?) If so, then you would have the same problem with a couple of other filters, like "<div>... Remove/Hide: Ad Containers - Headers". If that's the case then these filters are *not* broken for you, they only get mangled on edit/test, by the font. The Proxomitron GUI patch that i offer for download uses Andale Mono as preferred fixed font type (IIRC that change came from Henk's GUI). Hopefully you don't have problems to edit/test those many filters beginning with øþø or similar, like "Top Sniff: Sel. File Types". |
May. 25, 2009, 02:09 AM
(May. 24, 2009 09:33 PM)sidki3003 Wrote: Snippet from the filter code:I can see above code correctly in a text editor with Western European (iso-8859-1) encoding selected, but not correctly in mizzmona's patched prox. accents_prox.png (Size: 6.66 KB / Downloads: 874)
(May. 24, 2009 09:33 PM)sidki3003 Wrote: If so, then you would have the same problem with a couple of other filters, like "<div>... Remove/Hide: Ad Containers - Headers".No, I don't have problem with above mentioned filter. In deed, it has nothing to do with accents. It is because of mis-matched [] or (). I should have attached the snapshot earlier but I had thought you could reproduce that on your side, sorry ![]() syntax error.png (Size: 5.63 KB / Downloads: 727)
May. 25, 2009, 01:36 PM
That's the standard message if something in the editor isn't quite kosher.
Mona is using Andale Mono too: Code: 109 DIALOGEX 0, 0, 324, 206You do have that font installed, right? |
May. 25, 2009, 02:29 PM
Quote:You do have that font installed, right?Yes, I do have that font installed. You can see from the accents_prox.png that the number zero has a dot in the center. |
May. 26, 2009, 02:13 AM
Confirmed to be problem of mizzmona's PtronGUI patcher. The problem disappeared after using back the original version.
May. 26, 2009, 09:34 AM
(This post was last modified: May. 26, 2009 09:45 AM by sidki3003.)
Ahh okay. Yet, not everyone using it seems to be affected.
Does the same problem appear with Henk's or my patch? |
May. 27, 2009, 01:42 AM
I just tested your patch and it is not affected.
May. 27, 2009, 08:59 AM
Thanks. Perhaps that's getting further attention at some point, so i'm going to split this topic now.
