Trouble at Baidu
Apr. 30, 2009, 10:35 PM
Trouble at Baidu
Report: http://forum.proxomitron.cn/viewtopic.ph...80418#p943
Case: http://tieba.baidu.com/f?kz=571563171 Can someone who is affected please add below code to the very end of the ncFinal function in proxjs-full.js? Code: var sTag = document.getElementById("proxScrBot");Exactly *above*: Code: },This is just a test. Ideally - since leaving Proxomitron's inline scripts in place obviously imposes a security risk - each script should destruct itself just after execution. Regarding the document.domain problems also discussed in that thread, are they solved by the respective recently posted updates? |
May. 01, 2009, 02:23 AM
RE: Trouble at Baidu
(Apr. 30, 2009 10:35 PM)sidki3003 Wrote: Can someone who is affected please add below code to the very end of the ncFinal function in proxjs-full.js?Posting from IE8 and FF3.5B4 worked normally and didn't insert any code, even without applying your fix. I always get a post failure under opera, I will ask ddbb to test your solution and report back. (Apr. 30, 2009 10:35 PM)sidki3003 Wrote: Regarding the document.domain problems also discussed in that thread, are they solved by the respective recently posted updates?Solved under Opera 9.64, IE8 and FF3.5B4. I got below error under Opera Version 10.00 Alpha Build 1456. |
May. 01, 2009, 01:04 PM
Thanks
May. 02, 2009, 03:30 AM
| RE: Trouble at Baidu | |||
May. 02, 2009, 12:59 PM
I assume this means that posted code is required for Opera 9 stable.
Regarding Opera 10: I've (temporarily) installed the version you're using. Its same-origin policy appears to be quite similar to IE7, so implementing the fix wasn't difficult. Hopefully it works for others too. I'll post an update in the other thread later. In a possible future config version Opera 10 will get its own CSS fragment, to fix the radio controls in the Proxomitron menu. |
May. 06, 2009, 06:04 AM
May. 08, 2009, 02:22 PM
May. 21, 2009, 06:41 PM
As well as for user scripts. No self-destruction while in Debug Mode.
